Kinetis System Clocks
Suma_M
Supporting system clock frequency  supported by MKE15Z256VLL7 and MKE15Z256VLH7 fromKE1XZ256PB doc says is 48Mhz, but user manuals says 48MHz, 52MHz, 56Mhz and 60MHz. Attached image for reference.
Can anyone confirm if MKE15Z256VLL7 and MKE15Z256VLH7 micros supports more than 48Mhz for FIRC source??
danielchen
Hi Suma:
From datasheet, typical FIRC is 48M.
https://www.nxp.com/docs/en/data-sheet/KE1xZP100M72SF0.pdf
