Kinetis KV10 exposed pad connection
2,089件の閲覧回数
lukasbaumann
Can anybody confirm that the exposed pads of Kinetis KV10 devices are isolated from the die?
I can't find any information on the internal connection of the pad in the datasheet.
regards
Lukas
タグ(2)
3 返答(返信)
1,916件の閲覧回数
Paul_Tian
Hi, Lukas
As normal, the exposed pad will be internal connect to die. So you can connect it to ground. Thanks.
Best Regards
Paul
1,916件の閲覧回数
lukasbaumann
Hi Paul,
Thanks for your reply.
So then the exposed pad should be connected to digital ground? Or might it be better for the analog performance of the chip to connect it to analog ground?
Lukas
1,916件の閲覧回数
Paul_Tian
Hi, Lukas
You can connect to digital ground.
Best Regards
Paul
