Kinetis K60 RTC Interrupts When Debugging
markccrow
Since I've got the RTC alarm interrupt working (for a 1-second interrupt) I can't step through my code without getting redirected to the RTC IRQ routine.  Anyone had this problem or know of a fix?
BlackNight
Are you using CodeWarrior for MCU10.2?
The debugger launch configuration settings allow you to control this:
see attached screenshot.
Hope this helps,
BK
markccrow
Sorry it took me so long to answer.  I expected to get forum emails but they're not coming.  I think our email server is trashning them.
Yes, I have CW 10.2 but only use it for Processor Expert experimentation.  I'm developing with Keil's MDK-ARM tools.  May it has some control I can set.
