I am looking for clarification on the ERR010180 for the Kinetis Errata Mask 1N79P.
ERR010180 says the following:
What is meant by the '... the clock switch may hang.'?
My assumption is that, if you are switching from FIRC to SIRC, and an external reset is asserted, then you come out of reset still in the FIRC configuration, but the next time you go to switch to the SIRC, it will hang.
Is the above assumption correct?
