KW45B41Z83 Query
KW45B41Z83 Query
Ganesh_Pawar
Hello NXP Team,
I am currently using KW45 Microcontroller for my current project and i have some queries regarding it , need your inputs on it as mentioned below:-
1) Does KW45 MCU support Autosar ??
       If yes, kindly provide information regarding the same for implementation.
2) Does KW45 supports bootloader image feature ??, i dont find any example regarding it in the sdk example, i need to perform firmware upgrade, could you provide some input regarding it.
Requesting you to provide some inputs regarding this.
Thanks and regards,
Ganesh Pawar
luis_maravilla
Hello Ganesh
By any chance, do you already have a direct NXP contact or a sales representative? If you do not have any contact, please contact one of our distributors available in the Distributor Network|NXP to help you checking your request regarding the Autosar KW45 support.
KW45 supports bootloader using example called "otac_att"; I would recommend using the KW45 EVK latest SDK version [25.03] for checking this example, also this Application note describes an example and instructions on Creating firmware update image for KW45 https://www.nxp.com/docs/en/application-note/AN13860.pdf
Best Regards
Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2135721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW45B41Z83%20Query%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20using%20KW45%20Microcontroller%20for%20my%20current%20project%20and%20i%20have%20some%20queries%20regarding%20it%20%2C%20need%20your%20inputs%20on%20it%20as%20mentioned%20below%3A-%3C%2FP%3E%3CP%3E1)%20Does%20KW45%20MCU%20support%20Autosar%20%3F%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BIf%20yes%2C%20kindly%20provide%20information%20regarding%20the%20same%20for%20implementation.%26nbsp%3B%3C%2FP%3E%3CP%3E2)%20Does%20KW45%20supports%20bootloader%20image%20feature%20%3F%3F%2C%20i%20dont%20find%20any%20example%20regarding%20it%20in%20the%20sdk%20example%2C%20i%20need%20to%20perform%20firmware%20upgrade%2C%20could%20you%20provide%20some%20input%20regarding%20it.%3C%2FP%3E%3CP%3ERequesting%20you%20to%20provide%20some%20inputs%20regarding%20this.%3C%2FP%3E%3CP%3EThanks%20and%20regards%2C%3C%2FP%3E%3CP%3EGanesh%20Pawar%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45B41Z83%20Query%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Ganesh%3C%2FP%3E%0A%3CP%3EBy%20any%20chance%2C%20do%20you%20already%20have%20a%20direct%20NXP%20contact%20or%20a%20sales%20representative%3F%20If%20you%20do%20not%20have%20any%20contact%2C%20please%20contact%20one%20of%20our%20distributors%20available%20in%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsample-buy%2Fdistributor-network%3ADISTRIBUTORS%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDistributor%20Network%7CNXP%3C%2FA%3E%20to%20help%20you%20checking%20your%20request%20regarding%20the%20Autosar%20KW45%20support.%3C%2FP%3E%0A%3CP%3EKW45%20supports%20bootloader%20using%20example%20called%20%22otac_att%22%3B%20I%20would%20recommend%20using%20the%20KW45%20EVK%20latest%20SDK%20version%20%5B25.03%5D%20for%20checking%20this%20example%2C%20also%20this%20Application%20note%20describes%20an%20example%20and%20instructions%20on%20Creating%20firmware%20update%20image%20for%20KW45%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13860.pdf%23%3A~%3Atext%3DThis%2520document%2520provides%2520the%2520steps%2520to%2520create%2520and%2Cversion.%2520Each%2520version%2520uses%2520a%2520different%2520transfer%2520method.%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13860.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3ELuis%3C%2FP%3E%3C%2FLINGO-BODY%3E
