KW41Z pyocd flash Zephyr sample project
1,934 次查看
satsok_n
I am trying to run sample projects of zephyr RTOS on NXP KW41Z. I manage to build the project but I can't flash it to the board. According to the manual of zephyr(manual ref), I must use Pyocd to flash the elf file to the board. I installed pyocd through pip but when I try start pyocd gdbserver but I get stuck in this state:
I also try pyocd list but no available devices are found.
any suggestions?
标记 (3)
1,793 次查看
stephanie_m
I believe there are more requirements needed, could you please check this link ?
Estephania
