KW40Z "heart rate sensor" example code question
1,926 次查看
shinezen
Hello, we are programming board KW40Z and implementing some sample code.
In the "heart rate sensor" example, it requires us to press button SW4 to turn on the bluetooth, could you help us what to do in the code to turn on the bluetooth as the power is on?
Thanks for your help!
1 回复
1,742 次查看
danielkresta
