KW38 flash tool update version.
1,514 次查看
StephenYeh
Hi Sir,
Would you share me how to update the KW38 EVK flash tool FW?
Left is OK, Right side is fail.
BRs.
1,498 次查看
Ricardo_Zamora
Hope you are doing well. Could you please clarify what are you trying to achieve?
Are you trying to update the OpenSDA? If that is the case, you can check this page: OpenSDA Serial and Debug Adapter
There is a description on how to check the version on the board, and also how to update it.
Ricardo
