KV58F220M GHS FLASH ISSUE
Pavan_Moody
Hi Team, i am finding issue in downloading code in RAM. FYI PFA.
Output from command:
Green Hills Probe error 1 (general error).
ERROR 1 (general error): Icepick could not activate core.
load: Download failed.
Pavan_Moody
Executing setup script: C:\Users\Pavan.Jm\Downloads\KV58ramconfig\Project57\tgt\mpserv_standard.mbs
ERROR 1 (general error): SWD FAULT
ERROR 1 (general error): CTRL/STAT.STICKYERR set
ERROR 1 (general error): Couldn't read register trcpdsr on core 1.
I HAVE followed Jumper setup in manual still i have some other issue can you help me out .
Celeste_Liu
Hello @Pavan_Moody ,
Thank you for your post. Unfortunately, we don’t have Green Hills or the Green Hills probe available, so I’m unable to try it on my side. I tested using MCUXpresso and our SDK, and everything worked fine. SDK can be found here: Select Board | MCUXpresso SDK Builder. The test steps were as follows:
1. Import the SDK “Hello World” demo into mcuxpresso
2. Set the “Link application to RAM” option
3. Move RAM to position 1
4. Compile and debug
Everything ran without issues.
As for Green Hills, it is not one of our officially supported IDEs. If you prefer to continue using it, I recommend reaching out directly to their support team.
Thanks for your understanding and have a nice day.
Celeste
Pavan_Moody
Thank you for the response, where i can try linking RAM address in my starting script and try to get support from GHS
