KL26Z - 32.768Khz external crystal
2,311 次查看
_daniel_
Hi, please, I don't understand: How to using the external 32.768Khz crystal in the MKL26Z chip to get counter precision in date and time with the low power mode (LLS). I don't intend uses the internal LPO1khz. Thanks.
2,111 次查看
_daniel_
Thank you.
My conclusions for my application is:
>LPO with LPTMR is not good, why the interrupt is 1,0007 seconds.
>with external crystal 32.768khz, the core and bus clock is to low.
So, I will test the external RTC input clock with internal 4Mhz clock to core and 2Mhz to bus.
At the moment, I found another alternative, as soon as possible I will try to employ an crystal of the ABRACON - ASDK series.
http://www.mouser.com/ds/2/3/ASDK-24348.pdf
2,111 次查看
mjbcswitzerland
Specialist V
2,111 次查看
jingpan
Hi Daniel,
Please install MCUXpresso Config Tool and set clock tree like the picture below:
jing
