KEA128 CAN
KEA128 CAN
824件の閲覧回数
lzhjxgz
我用KDS3.0生成库代码,生的CAN代码PE_ISR(CAN1_TxInterrupt),
ErrorFlags = MSCAN_PDD_GetRxStatusInterruptFlags(MSCAN_BASE_PTR); /* Read the status register */
if (
    ((ErrorFlags & MSCAN_PDD_RX_BUS_OFF) != MSCAN_PDD_RX_BUS_OFF)||         ((ErrorFlags & MSCAN_PDD_TX_BUS_OFF) != MSCAN_PDD_TX_BUS_OFF)
  { /* Is bus-off detected? */
      DeviceDataPrv->Stats.BusOffs++;  /* Increase BusOffs interrupt counter */
      CAN1_OnBusOff(DeviceDataPrv->UserData); /* Invoke user event */
MSCAN_PDD_RX_BUS_OFF为0x30,查看手册中 MSCAN_CANRFLG ,bit5-4中为0b11时总线离线,但代码中判断不为0b11则为离线。
LDD_TError CAN1_GetError(LDD_TDeviceData *DeviceDataPtr, LDD_CAN_TErrorMask *ErrorMaskPtr)
CAN1_TDeviceData *DeviceDataPrv = (CAN1_TDeviceData *)DeviceDataPtr;
/* {Default RTOS Adapter} Critical section begin, general PE function is used */
EnterCritical();
*ErrorMaskPtr = DeviceDataPrv->ErrorMask; /* Return last value of error mask */
DeviceDataPrv->ErrorMask = 0x00U;
/* {Default RTOS Adapter} Critical section end, general PE function is used */
ExitCritical();
return ERR_OK;
DeviceDataPrv->ErrorMask = 0x00U;,查看代码ErrorMask 为内存中数据,为什么ErrorMask 清零后总线可以立刻恢复。
729件の閲覧回数
HI @lzhjxgz
Thanks for your patience.
1.Regarding “MSCAN_PDD_RX_BUS_OFF为0x30,查看手册中 MSCAN_CANRFLG ,bit5-4中为0b11时总线离线,但代码中判断不为0b11则为离线”,
->> I agree with you — the Bus‑Off detection logic in the code is indeed opposite to what is described in the hardware manual.
Please the code manually and check whether it works correctly. I will also report this issue to the internal team.
2. For  second question, I think there is no relationship between clearing ErrorMask and the CAN bus being restored. The Bus‑Off recovery is handled entirely by the hardware mechanism.
Thank you.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2333124%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EKEA128%20CAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333124%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EKDS3.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81CAN%E3%82%B3%E3%83%BC%E3%83%89PE_ISR(CAN1_TxInterrupt)%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EErrorFlags%20%3D%20MSCAN_PDD_GetRxStatusInterruptFlags(MSCAN_BASE_PTR)%3B%20%2F*%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%20*%2F%3C%2FP%3E%3CDIV%3E%E3%82%82%E3%81%97%20%EF%BC%88%3C%2FDIV%3E%3CDIV%3E((ErrorFlags%20%26amp%3B%20MSCAN_PDD_RX_BUS_OFF)%20!%3D%20MSCAN_PDD_RX_BUS_OFF)%7C%7C%20((ErrorFlags%20%26amp%3B%20MSCAN_PDD_TX_BUS_OFF)%20!%3D%20MSCAN_PDD_TX_BUS_OFF)%3C%2FDIV%3E%3CDIV%3E%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%7B%20%2F*%20%E3%83%90%E3%82%B9%E3%81%8C%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDeviceDataPrv-%26gt%3BStats.BusOffs%2B%2B%3B%20%2F*%20BusOffs%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ECAN1_OnBusOff(DeviceDataPrv-%26gt%3BUserData)%3B%20%2F*%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3EMSCAN_PDD_RX_BUS_OFF%20%E3%81%AF%200x30%20%E3%81%A7%E3%81%99%E3%80%82%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3CSPAN%20class%3D%22%22%3EMSCAN_CANRFLG%3C%2FSPAN%3E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%205-4%20%E3%81%AF%200b11%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%200b11%20%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%AA%E3%83%95%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CP%3ELDD_TError%20CAN1_GetError(LDD_TDeviceData%20*DeviceDataPtr%2C%20LDD_CAN_TErrorMask%20*ErrorMaskPtr)%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3ECAN1_TDeviceData%20*DeviceDataPrv%20%3D%20(CAN1_TDeviceData%20*)DeviceDataPtr%3B%3C%2FP%3E%3CP%3E%2F*%20%7BDefault%20RTOS%20Adapter%7D%20%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%8B%E5%A7%8B%E3%80%81%E6%B1%8E%E7%94%A8PE%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%20EnterCritical()%3B%3CBR%20%2F%3E%20*ErrorMaskPtr%20%3D%20DeviceDataPrv-%26gt%3BErrorMask%3B%20%2F*%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E5%80%A4%E3%82%92%E8%BF%94%E3%81%99%20*%2F%3CBR%20%2F%3E%20DeviceDataPrv-%26gt%3BErrorMask%20%3D%200x00U%3B%3CBR%20%2F%3E%20%2F*%20%7BDefault%20RTOS%20Adapter%7D%20%E3%82%AF%E3%83%AA%E3%83%86%E3%82%A3%E3%82%AB%E3%83%AB%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E7%B5%82%E4%BA%86%E3%80%81%E6%B1%8E%E7%94%A8PE%E9%96%A2%E6%95%B0%E3%82%92%E4%BD%BF%E7%94%A8%20*%2F%3CBR%20%2F%3E%20ExitCritical()%3B%3CBR%20%2F%3E%20return%20ERR_OK%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3EDeviceDataPrv-%26gt%3BErrorMask%20%3D%200x00U%3B%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ErrorMask%20%E3%81%AF%E3%83%A1%E3%83%A2%E3%83%AA%E5%86%85%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A7%E3%81%99%E3%80%82ErrorMask%20%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%AA%E3%81%9C%E3%83%90%E3%82%B9%E3%81%AF%E3%81%99%E3%81%90%E3%81%AB%E5%9B%9E%E5%BE%A9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2333124%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKinetis%20EA%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAMCU%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KEA128%20CAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260710%22%20target%3D%22_blank%22%3E%40lzhjxgz%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E3%81%94%E8%BE%9B%E6%8A%B1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E3%80%8C%20%3CSPAN%3EMSCAN_PDD_RX_BUS_OFF%20%E3%81%AF%200x30%20%E3%81%A7%E3%81%99%EF%BC%8C%E6%89%8B%E5%86%8C%E4%B8%AD%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EMSCAN_CANRFLG%20%E3%82%92%3C%2FSPAN%3E%E8%A6%8B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%3E%EF%BC%8Cbit5-4%20%E3%81%AF%200b11%20%E6%99%82%E6%80%BB%E7%B7%9A%E7%A6%BB%E7%B7%9A%E3%81%A7%E3%81%99%E3%81%8C%EF%BC%8C%E4%BB%A3%E6%A1%88%E3%81%A7%E3%81%AF%200b11%20%E3%81%AF%E7%A6%BB%E7%B7%9A%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%8D%3C%2FP%3E%0A%3CP%3E-%26gt%3B%26gt%3B%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%84%8F%E8%A6%8B%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E3%83%90%E3%82%B9%E3%82%AA%E3%83%95%E6%A4%9C%E5%87%BA%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E9%80%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AF%E7%A4%BE%E5%86%85%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E3%82%82%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%202%E3%81%A4%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3CCODE%20translate%3D%22no%22%3EErrorMask%3C%2FCODE%3E%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A8CAN%E3%83%90%E3%82%B9%E3%81%8C%E5%BE%A9%E5%85%83%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%82%B9%E5%81%9C%E6%AD%A2%E3%81%8B%E3%82%89%E3%81%AE%E5%BE%A9%E6%97%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%A9%9F%E6%A7%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%AA%E3%82%B9%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
