K81 Temperature Tamper setting
已解决
跳至解决方案
3,490 次查看
Casper
I heard the K21 could be set to different temperature scopes for the tamper module.
Could the K81 temperature TAMPER be set in different scopes?
1 解答
3,388 次查看
vicentegomez
Please accept my apologies for my mistake.
I have checked and yes those registers are used to set the trim for the temperature tamper.
在原帖中查看解决方案
4 回复数
3,403 次查看
Casper
Hi vicentegomez,
Thanks for the response.
I found the Tamper Trim Register from the K81 Reference manual.
is it works?
Thanks.
3,389 次查看
vicentegomez
3,359 次查看
Casper
Thank you for the confirmation.
It's very helpful for us.
3,456 次查看
vicentegomez
As far as I know, it is no possible.
