Hello everyone,
I am new to the Nxp community and Kinetis development.I would like to make an application from which the Frdm K66F sends data via UDP (or TCP) to a computer.The support and documentation are mostly non-existent on this topic,my question is how would you go about making this happen ? Perhaps you could point me to some example or reference,if there exists such thing.
Best wishes :smileyhappy:
Hi Doru,
I'd highly recommend you to refer to the set of lwip demos which is from the KSDK2.0, and in the set of lwip demos, it contains a TCP echo and a UDP echo demo.
Hope it helps,
Ping
Hai.,
I am also using K66 MCU.
As per your suggestion I used SDK2.0 (lwip_UDP_echo)example , Its working perfectly.
Now Can you help me to modify the example as per our requirement, so that it should not echo back UDP packet, instead i need simple UDP receive/ send example.
I tried by removing echo send function , but in PC side it still waiting for UDP echo packet.
thank you.,
Best Regards.,
karthik
