K64 Temperature Sensor associated with ADC
ソリューションへジャンプ
2,878件の閲覧回数
JHinkle
Senior Contributor I
I'm embarrassed to ask but I can't find how to access the internal temperature sensor of the K64.
The documentation says the PN diode is attached to one of the ADC pins but that's it.
Where can I find which ADC channel has access to the temperature sensor?
Thanks.
Joe
タグ(1)
2,440件の閲覧回数
JHinkle
Found it.
Sorry for the question.
2 返答(返信)
2,440件の閲覧回数
egoodii
Senior Contributor III
Details about particulars for any specific chip are in section 3 of the reference manuals.  You should find a 'channel assignment' table in the analog section with this detail -- I expect you will find temp-sense on AD26.
I hope you have read my post about how to use this input.
2,441件の閲覧回数
JHinkle
Found it.
