K64 Pin Mux (Flexbus)
1,223 次查看
aneeshkumarvr
Hi ,
   I need to use K64 , flexbus 8bit , mode to connect with FPGA , I wan to confirm if I configure flexbus 8 bit and remaining 24 lines can it be configure in any other pinmux ALT functions .
1,023 次查看
miduo
Sure, it can. And for Kinetis family, it also supports dynamically modify pin function by Pin Control Register (PORTx_PCRn) register.
