K61/K70 EWARM .MAC file to init DDR?
1,633 次查看
exoson
Fresh Out Contributor
Does anyone have a working .mac file they can share to init the SDRAM (DDR2) on a K61/K70?
Using a TWRK70F120 and would like to initialize the DDR2 when the debugger starts so we can download code into the SDRAM.
I found one in the K70 Sample Code (KINETIS_120MHZ_SC.zip) but it doesn't seem to work on this board.
Scott
标记 (5)
1 回复
1,361 次查看
exoson
I found a solution.  The sample .mac file is fixed in the examples for EWARM v6.70.
Filename is K70_MT47H64M16HR-3.mac
