K22FN512 UART FIFO Depth
1,706 次查看
derekcook
Senior Contributor I
In the reference manual I am having a hard time finding out information on FIFO depth for this microcontroller. I see how to define FIFO depth in the UARTx_PFIFO, but does each UART0 and UART1 allow the same FIFO depth.
I know on the KV31 UART0 is much deeper than UART1 - I just wanted to check if this is the same for the K22 or if both UARTs can be defined the max depth - Just want to be sure my design is correct.
标签 (2)
1,564 次查看
mjbcswitzerland
Specialist V
Hi Derek
Mark
1,564 次查看
derekcook
Thanks Mark - I didn't see that in the reference manual. That helped me out.
