K20 DSPI controlling SS
DustyStew
Contributor V
I'm looking at the DSPI docs and haven't yet found how to best go about controlling slave select. Can someone provide some insight as to how the designers intended that a programmer would control a single slave select pin? Program the PCS pin as GPIO? Use the polarity control for the PCS? Put the SPI in slave mode?
TIA
Tom
Hui_Ma
Customer could control the chip select signal with PUSH TX FIFO Register In Master Mode (SPIx_PUSHR) register [PCS[5:0]] bits.
Before set related register, customer need to config related pin with DSPI chip select function.
Wish it helps.
