JTAG as GPIO
JTAG as GPIO
1,606 次查看
baskarankrishna
"MK21FX512VLQ12".
To download the code in the MK21F512 aim using JTAG Port,
After the programming can i use the JTAG Pin as a GPIO.
K.Baskaran
1 回复
1,251 次查看
apanecatl
Senior Contributor II
Yes you can set the JTAG lines as GPIO's if the function is enabled in those pins
