JPEG Compression
JPEG Compression
josephchen
Does any one know how long it will take for MK70 to compress a 720p (1280x720) and 10bits per pixel image to JPEG format?
briandavidson1
It requires consulting the specific technical specifications or testing of the MK70 device. For optimal image compression and website performance here is jpeg compressor tool such as https://jpegcompressor.com/ that efficiently optimize various image formats, reducing file sizes without compromising quality with the help of this tool you can check and analyze.
Thank you.
