Is it possible to send CAN-FD messages with the cortex m0+?
1,381 次查看
andrehart
Hey together,
is it possible to send CAN-FD messages with the cortex m0+. The controller is on the FRDM-KEAZ64Q64-ND development board.
So do you know any CAN (FD) transceiver, that I can use to "convert" the CAN message from the onboard CAN Controller to a CAN FD message?
Is it possible?
Thank you and best
Andre
1 回复
1,287 次查看
ndavies
Contributor V
No, changing just the transceiver will not work. You must have a CAN controller that supports CAN-FD to send CAN-FD data. The other issue I would have with an M0+ device is data throughput. I don't see it keeping up.
Norm Davies
Accurate Technologies Inc.
