Is it possible to program internal EEPROM memory of freescale micro-controller MKE02z32 using Jlink Programmer?
gagan
MKE02z32 micro-controller has internal 256 byte eeprom memory. can we program it using Jflash programmer?
kerryzhou
Hi gagan gupta,
     About this question, I think you may already get the answer from the segger engineer's reply in my former post in the segger community.
    [SOLVED] JFLASH ERROR:Program (0x10000000 - 0x100000FF) does not fit into selected flash sectors - J...
    Wish it helps you!
Kerry
