Is MMCAU performance enough?
4,091件の閲覧回数
yasuhikokoumoto
Senior Contributor I
Hi all,
I would like to know a practicality of the MMCAU. Have anyone applied the MMCAU to real applications (e.g. SSL communication)? In such case, is the performance enough? I'm afraid the MMCAU cannot be applied to real applications because of its (probably) low performance. The background of this question is that I was told by my friend who has used the MMCAU for SSL communication says that the MMCAU performance had been very low. Can anyone correct me if he has good experience?
Yasuhiko Koumoto.
ラベル(2)
タグ(3)
3,909件の閲覧回数
miduo
Actually I am not sure which part you would like to operate. As for the performace of the MMCAU, it is quite dependent. I am attaching a performance report we had done for you reference.
3,909件の閲覧回数
miduo
3,909件の閲覧回数
yasuhikokoumoto
Hi Fang Li,
thank you very much. They are very interested materials. I am satisfied.
However 100Mbps transaction is difficult with the mmCAU, isn't it?
Yasuhiko Koumoto.
