Implementing a Handler to Request a USB Set Descriptor
dmytrogrytsay
Greetings
Has anyone implemented a Set Descriptor request handler for a USB device?
There is a problem on this issue:
- what should be the correct response of the device to this request.
In particular, the NXP Kinetis family of microcontrollers is of interest. The proposed NXP has a usb stack, but there is no SET SCRIPTOR implementation on the stack.
By analogy with other queries, Set Descriptor was also implemented. As a result, this works, but cannot access the data field.
But any example will also be useful.
Tags (3)
bobpaddock
Senior Contributor III
Some of the NXP USB Stacks are based on LUFA.  It has lots of examples, see if any help:
GitHub - abcminiuser/lufa: LUFA - the Lightweight USB Framework for AVRs.
