Implementation of the automotive VPW protocol
1,643 次查看
carrielbr
good Morning
Can someone help me carry out the implementation of the automotive VPW protocol?
I'm able to write, however I am unable to use the timers efficiently to receive a message.
thank you
标记 (3)
1,481 次查看
xiangjun_rong
Hi Caio,
I am not familiar with the VPW protocol, I have asked the FAE of automotive, the VPW is a High level protocol for automotive monitoring by the Car manufacturer. After searching the website, I found a lot of doc including application not, hope it can help you.
http://tinyurl.com/hfzqem5
For detailed technical problem, pls tell us detail, for example the part number, the peripheral, the tools you are using, the concrete problem you have... so that we can support you.
XiangJun Rong
