IBIS models for K10 parts
1,509 次查看
tsweeney
Are there IBIS models for the Kinetis K10-72MHz parts?  I have ibis models for the K10-120MHz parts.  Could the 120MHz models be used for 72MHz parts?
2 回复数
1,508 次查看
tsweeney
Also, do the IBIS models allow for open drain simulations?  The only models I see for GPIO pins are full drive mode/low drive mode and with slew rate/without slew rate.
1,499 次查看
jingpan
Please find your part number in https://www.nxp.com/design/software/models/microcontroller-symbols-footprints-and-models:MCUCAD?&fsr....
If it says 'request file', then you have to send request. Someone will generate this file according to your request. But you have to wait very long time.
Jing
