How to use hrs.py script on my linux host to send command to kw41z blackbox?
2,049件の閲覧回数
devangdixit
$ python hrs.py
usage: hrs.py [-h] [-p] <serial_port ble_fsci_black_box>
hrs.py: error: too few arguments
I have flashed hybrid black box binary in my kw41z dev kit.
and using the above script as follows to send command to the black box:
$ python hrs.py /dev/ttyACM2 -p
Namespace(dev='/dev/ttyACM2', pair=True)
[Command 0] /dev/ttyACM2: FSCICPUResetRequest -> { }
[Command 1] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x1801 }
No response for the previous command GATTDBDynamicAddPrimaryServiceDeclarationRequest
[Command 2] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x1801 }
[Command 3] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0x0'] , Uuid: 0x2a05 , MaxValueLength: 0x0 , CharacteristicProperties: 0x12 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x0 }
No response for the previous command GATTDBDynamicAddCharacteristicDeclarationAndValueRequest
[Command 4] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0x0'] , Uuid: 0x2a05 , MaxValueLength: 0x0 , CharacteristicProperties: 0x12 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x0 }
[Command 5] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
No response for the previous command GATTDBDynamicAddCccdRequest
[Command 6] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
[Command 7] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x1800 }
[Command 8] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x1800 }
[Command 9] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4b696e6574697320424c4500 , Uuid: 0x2a00 , MaxValueLength: 0x14 , CharacteristicProperties: 0x2 , InitialValueLength: 0xc , ValueAccessPermissions: 0x1 }
[Command 10] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4b696e6574697320424c4500 , Uuid: 0x2a00 , MaxValueLength: 0x14 , CharacteristicProperties: 0x2 , InitialValueLength: 0xc , ValueAccessPermissions: 0x1 }
[Command 11] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0'] , Uuid: 0x2a01 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x2 , ValueAccessPermissions: 0x1 }
[Command 12] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0'] , Uuid: 0x2a01 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x2 , ValueAccessPermissions: 0x1 }
[Command 13] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0xA', '0x0', '0x10', '0x0', '0x64', '0x0', '0xE2', '0x4'] , Uuid: 0x2a04 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 14] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0xA', '0x0', '0x10', '0x0', '0x64', '0x0', '0xE2', '0x4'] , Uuid: 0x2a04 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 15] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180d }
[Command 16] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180d }
[Command 17] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0xB4'] , Uuid: 0x2a37 , MaxValueLength: 0x16 , CharacteristicProperties: 0x10 , InitialValueLength: 0x2 , ValueAccessPermissions: 0x0 }
[Command 18] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0xB4'] , Uuid: 0x2a37 , MaxValueLength: 0x16 , CharacteristicProperties: 0x10 , InitialValueLength: 0x2 , ValueAccessPermissions: 0x0 }
[Command 19] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
[Command 20] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
[Command 21] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x1'] , Uuid: 0x2a38 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x1 }
[Command 22] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x1'] , Uuid: 0x2a38 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x1 }
[Command 23] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0'] , Uuid: 0x2a39 , MaxValueLength: 0x0 , CharacteristicProperties: 0x8 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x10 }
[Command 24] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0'] , Uuid: 0x2a39 , MaxValueLength: 0x0 , CharacteristicProperties: 0x8 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x10 }
[Command 25] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180f }
[Command 26] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180f }
[Command 27] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x5A'] , Uuid: 0x2a19 , MaxValueLength: 0x0 , CharacteristicProperties: 0x12 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x1 }
[Command 28] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x5A'] , Uuid: 0x2a19 , MaxValueLength: 0x0 , CharacteristicProperties: 0x12 , InitialValueLength: 0x1 , ValueAccessPermissions: 0x1 }
[Command 29] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDescriptorRequest -> { DescriptorAccessPermissions: 0x1 , UuidType: 0x1 , DescriptorValueLength: 0x7 , Uuid: 0x2904 , Value: ['0x4', '0x0', '0xAD', '0x27', '0x1', '0x0', '0x0'] }
No response for the previous command GATTDBDynamicAddCharacteristicDescriptorRequest
[Command 30] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDescriptorRequest -> { DescriptorAccessPermissions: 0x1 , UuidType: 0x1 , DescriptorValueLength: 0x7 , Uuid: 0x2904 , Value: ['0x4', '0x0', '0xAD', '0x27', '0x1', '0x0', '0x0'] }
[Command 31] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
[Command 32] /dev/ttyACM2: GATTDBDynamicAddCccdRequest -> { }
[Command 33] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180a }
[Command 34] /dev/ttyACM2: GATTDBDynamicAddPrimaryServiceDeclarationRequest -> { UuidType: 0x1 , Uuid: 0x180a }
[Command 35] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4e585000 , Uuid: 0x2a29 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x1 }
[Command 36] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4e585000 , Uuid: 0x2a29 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x1 }
[Command 37] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4b696e6574697320424c4500 , Uuid: 0x2a24 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0xc , ValueAccessPermissions: 0x1 }
[Command 38] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x4b696e6574697320424c4500 , Uuid: 0x2a24 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0xc , ValueAccessPermissions: 0x1 }
[Command 39] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x424c45534e303100 , Uuid: 0x2a25 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 40] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x424c45534e303100 , Uuid: 0x2a25 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 41] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x5553422d4b5734315a2d4b32324600 , Uuid: 0x2a27 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0xf , ValueAccessPermissions: 0x1 }
[Command 42] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x5553422d4b5734315a2d4b32324600 , Uuid: 0x2a27 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0xf , ValueAccessPermissions: 0x1 }
[Command 43] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x312e312e3100 , Uuid: 0x2a26 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x6 , ValueAccessPermissions: 0x1 }
[Command 44] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x312e312e3100 , Uuid: 0x2a26 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x6 , ValueAccessPermissions: 0x1 }
[Command 45] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x312e312e3400 , Uuid: 0x2a28 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x6 , ValueAccessPermissions: 0x1 }
[Command 46] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: 0x312e312e3400 , Uuid: 0x2a28 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x6 , ValueAccessPermissions: 0x1 }
[Command 47] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0xFE', '0xFF', '0x9F', '0x4', '0x0'] , Uuid: 0x2a23 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 48] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0xFE', '0xFF', '0x9F', '0x4', '0x0'] , Uuid: 0x2a23 , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x8 , ValueAccessPermissions: 0x1 }
[Command 49] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0x0'] , Uuid: 0x2a2a , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x1 }
[Command 50] /dev/ttyACM2: GATTDBDynamicAddCharacteristicDeclarationAndValueRequest -> { UuidType: 0x1 , InitialValue: ['0x0', '0x0', '0x0', '0x0'] , Uuid: 0x2a2a , MaxValueLength: 0x0 , CharacteristicProperties: 0x2 , InitialValueLength: 0x4 , ValueAccessPermissions: 0x1 }
[Command 51] /dev/ttyACM2: GAPReadPublicDeviceAddressRequest -> { }
No response for the previous command GAPReadPublicDeviceAddressRequest
[Command 52] /dev/ttyACM2: GAPReadPublicDeviceAddressRequest -> { }
[Command 53] /dev/ttyACM2: GAPRegisterDeviceSecurityRequirementsRequest -> { SecurityRequirements: <com.nxp.wireless_connectivity.commands.ble.frames.SecurityRequirements object at 0x8e20f2c> , SecurityRequirementsIncluded: 0x1 }
[Command 54] /dev/ttyACM2: GAPSetLocalPasskeyRequest -> { Passkey: 0xf423f }
[Command 55] /dev/ttyACM2: GAPSetAdvertisingDataRequest -> { AdvertisingDataIncluded: 0x1 , ScanResponseData: None , ScanResponseDataIncluded: 0x0 , AdvertisingData: <com.nxp.wireless_connectivity.commands.ble.frames.AdvertisingData object at 0x8e2084c> }
No response for the previous command GAPSetAdvertisingDataRequest
[Command 56] /dev/ttyACM2: GAPSetAdvertisingDataRequest -> { AdvertisingDataIncluded: 0x1 , ScanResponseData: None , ScanResponseDataIncluded: 0x0 , AdvertisingData: <com.nxp.wireless_connectivity.commands.ble.frames.AdvertisingData object at 0x8e2612c> }
Traceback (most recent call last):
File "hrs.py", line 886, in <module>
main(args)
File "hrs.py", line 835, in main
dev.gatt_server_register_for_write_notifications(gBleSig_BatteryService_d)
File "hrs.py", line 607, in gatt_server_register_for_write_notifications
AttributeHandles=[self.handles[service_uuid]],
KeyError: 6159
2 返答(返信)
1,970件の閲覧回数
stephanie_m
Could you please make sure you followed all the installation steps mentioned in the Kinetis FSCI Host Application Programming Interface. This file's available in the documentation folder and you could also check the chapter 9.4 of the document where there is a detailed description of how to run the example.
C:\<installation path>\SDK_2.2_FRDM-KW41Z\docs\wireless\Thread
Please, let me know if this works for you.
1,970件の閲覧回数
devangdixit
I want to know that how to modify that(hrs.py) script to make the black box work as a central and start scanning and initiate the connection to scanned device .
More specifically can u please tell me the sequence of commands to be sent to the black box to make it work as central.
