How to report bugs in documentation?
jrychter
Contributor V
The "KL05 Sub-Family Reference Manual" section on LLWU is really hard to interpret because of a search&replace gone wrong:
All LLWU registers are reset by Chip Reset not VLLS and by reset types that trigger Chip Reset not VLLS. Each register's displayed reset value represents this subset of reset types. LLWU registers are unaffected by reset types that do not trigger Chip Reset not VLLS.
More generally, where and how does one report such problems?
Tags (2)
Paul_Tian
Hi, Jan
As normal, you can raise a service request to www.freescale.com . Then your document question will go into Freescale internal process. We will check your question and reply whether it is a document issue. Hope my reply is clear for you.
Best Regards
Paul
Paul_Tian
Hi, Jan
Best Regards
Paul
jrychter
Contributor V
Thank you -- I reported the problem and got a reply, the issue will be addressed in future revisions.
