How to flash K60N512 with CodeWarrior 10.4 for offline running (Not in debugging mode)
已解决
跳至解决方案
2,364 次查看
yonggonlee
I just started using CodeWarrior 10.4 for my K60N512 tower. I was able to compile and debug some example projects without problem. Now I want to program the tower so that it runs without the debugger. My test projects blinks the orange LED. When in debugging mode it works fine. How I can now program the target so that the LED blinking works only by supplying power, for example, via wall outlet USB adapter. I could not find any doc or instruction regarding this. Please help.
标签 (1)
标记 (3)
1 解答
2,019 次查看
yonggonlee
Jennie, thank you so much for your help. After a lot of frustration I just wiped out CW and Freescale MQX, downloaded latest versions of them (even though I knew I had latest version) and reinstalled them. And Wa-Lah! It is working without any issue. So I did not fix anything.
However, based on your comment I had a chance to learn a lot about Cortex M4 and CW. So I want to thank  you.
By the way, it is my first time working with RTOS which is a whole new experience for a old timer like me. And I am so excited.
在原帖中查看解决方案
2 回复数
2,019 次查看
ZhangJennie
i beleive you can find the answer in Erich blog:
Standalone Flash Programmer
http://mcuoneclipse.com/2012/08/02/standalone-flash-programmer/
CodeWarrior Flash Programming from a DOS Shell:
http://mcuoneclipse.com/2012/08/03/codewarrior-flash-programming-from-a-dos-shell/
2,020 次查看
yonggonlee
