How to Switch RTC from External Oscillator to Internal Oscillator on KM34
1,452 次查看
Gohil
I am working on a project using the NXP MKM34Z256 microcontroller, and I need to change the RTC clock source from the external oscillator (32.768 kHz) to the internal LPO (1 kHz). I've been referencing the NXP documentation and SDK examples, but I'm encountering issues with the transition.
Could someone provide guidance or a correct procedure for switching the RTC clock source from the external 32.768 kHz oscillator to the internal 1 kHz LPO on the MKM34Z256? Any sample code or references to documentation would be greatly appreciated.
Thank you in advance for your help!
 Raj.
1,422 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
Yes, there is no documentation/demos about that. But personally is more illustrative/easiest work with clocks configuration with Clocks Tool from Config Tool.
Hope it helps you.
Have a nice day!
