How many GPIO ports does the MK10FX512VLQ12 have?
garylynch
I am writing an initialization routine for the MK10FX512VLQ12 MCU on a board we designed. In the "K10 Sub-Family Reference Manual with Addendum":
- https://www.nxp.com/docs/en/reference-manual/K10P144M120SF3RM.pdf
page 260, there is a table showing 6 ports, A through F. Furthermore when I generate a new project with KDS 3.2.0, it creates a header called \Includes\MK10F12.h which defines base addresses for 6 ports (lines 4461-4487).
However on pp. 246-247 of the same reference manual we see the pinouts of the LQFP and MAPBGA packages and there are only 5 I/O ports (No trace of port F). I can find no sign of it anywhere else in the reference manual.
I am a little concerned that I can configure and drive a port that doesn't exist. Is there a good reason for this?
garylynch
Thanks, Robin!  Will do.
Robin_Shen
Hi Gary Lynch,
Sorry for the inconvenience!
The part number listed in K10P144M120SF3RM don't have PORTF, please don't use this port in software.
Robin
