How Can I flash to FlashROM using SWD?
2,979 次查看
sakoh10
I'm programming on IAR Embedded(EWARM). and using chipset MKL16Z128.
Usually, I used Universal Bootloader AN2295 by Freescale.
It can use only UART as interface. But I want to use SWD convenience.
(In maintenance, debug and flashing do one port)
But I couldn't find out how to write using by SWD.
Flash Magic has no item as MKL16Z128. there is only MKW41Z512 as ARM Kinetis Cortex.
Anyone knows?
Please teach me how to write FlashRom using SWD.
thanks.
标签 (1)
标记 (2)
1 回复
2,402 次查看
miduo
Please make reference below application note, which including detailed information on how to flashing Kinetis by different hardware interface:
https://www.nxp.com/docs/en/application-note/AN4835.pdf
