Hi,Is there any possibility to interface SD card with tower kit?
1,988件の閲覧回数
nimmisatheendra
I am using Tower kit with K53, now I want to store the data on SD card, Is there any possibility for the same??
If I will get any sample code for SD card interfacing???
3 返答(返信)
1,823件の閲覧回数
jeremyzhou
Hi Nimmi,
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
The TWR-K53N512 has the SD socket, and  I'd highly recommend you to refer to the SD demo code below.
Sd-Card Fat file system Project for Freescale Kinetis.rar
Ping
1,823件の閲覧回数
nimmisatheendra
Hi Jeremyzhou,
Thank you for your suggestion. There is a problem, I am using IAR workbench. Can you please provide me the sample code for IAR workbench??
1,823件の閲覧回数
jeremyzhou
Hi Nimmi,
You can also find the sdhc_cdcard demo in the ~\SDK_2.0_FRDM-K64F\SDK_2.0_FRDM-K64F\boards\frdmk64f\driver_examples after you install the KSDK 2.0.
Please go to download the KSDK 2.0 through the link as below.
Software Development Kit for Kinetis MCUs|NXP
Hope it helps.
Ping
