[Help]Document or Tutorial with MAPS-KS22F256 main and dock board
tienchuan
Hi everyone.
I'm beginner with ARM cortex MCU.
I get a MAPS-KS22F256 main and dock board to learn programming.
I tried to search document on NXP site but almost is China langguage, it make me difficult to understand(using google translate to English )
Now, I want to get more doc or tutorial of this dev KIT.
Please show me some basic tut ( getting started , build project, blink led,.....on KEIL MDK).
I have just downloaded KS22 SDK but i don't known the way to build and download to dev KIT.
Please help me .
Thanks you.
kerryzhou
Hi Nguyen TienChuan,
    Because the MAPS-KSSF256 is the China local board, then all the document is in Chinese, no English document.
    I suggest you use the KSDK2.0_MAPS-KS22 to get start, you already download that sample code.
   About the build, and download, you can refer to the document in the KSDK:SDK_2.0_MAPS-KS22\docs
Getting Started with Kinetis SDK (KSDK) v.2.0.pdf
  You also can refer to this video to operation it:
MAPS-KS22快速上手视频|NXP
Wish it helps you!
If you still have problem, just let me know!
Kerry
