Have problem to run a code in KL25z
1,189 次查看
Amir_Nasiri
Hello Community,
破坏者
破坏者
I am trying to run a code using KL25z, but I have faced errors as follows. I will be thankful if someone can give me some advice and help me. I also attached the code.
1 回复
1,175 次查看
Pavel_Hernandez
I can't replay your error, I recommend uninstalling the SDK and downloading the last version, and trying again. I opened your code and compile it, but I only can see a warnings flags, so I changed it to this.
if((GPIO_ReadPinInput(SW1_PORT, SW1_PIN) == 0) |
(GPIO_ReadPinInput(SW2_PORT, SW2_PIN) == 0) |
(GPIO_ReadPinInput(SW3_PORT, SW3_PIN) == 0) |
(GPIO_ReadPinInput(SW4_PORT, SW4_PIN) == 0) |
(GPIO_ReadPinInput(SW5_PORT, SW5_PIN) == 0) |
(GPIO_ReadPinInput(SW6_PORT, SW6_PIN) == 0))
Pavel
