Getting "Write memory failed: address 0x0" error message
geochrist
Hi there,
We are getting a
Expected value:  0x1fffc420
Actual value:        0xffffffff
when trying to program a home made PCB that contains a MK40X512 device.  After this message, we get
[Chinese text] , A verify error has occurred while writing memory
We are using a PE Mimcrosystems USB Multilink Universal (RevA) (USB-ML-UNIVERSAL) programmer.
The programming succeeds when burning in the same program to a K40-KIT demo kit.  (This kit has
a MK40X256 in it, though.)
Has anyone seen this before, or does anyone have any ideas what might be going on?
Thanks.
George
javier1
I get the same problem, but i use a custom board with PK60N512VMD100.
Write memory failed: address 0x0.
Expected value: 0x1fff7598
Have you solved your problem?
Help, please.
thanks to all!!
geochrist
I remember the problem being a bad chip.  Needed a new one.
javier1
Are you sure? My chip is a BGA package and can´t quit and put!!
The K60 is new from arrow, and i have tested with 2 custom boards...
geochrist
Maybe your board is bad, then.  Sorry, but it was a while ago and I'm just repeating what my engineer told me.
Regards.
javier1
Can you tell me the mask of your ICs?
Thanks again.
geochrist
I'm sorry but I don't have that information.  I am not working on that project anymore and no longer have access to the data.
Best wishes to you.
