GPIO interrupt
GPIO interrupt
3,792件の閲覧回数
prakashpatel
I am trying to setup external interrupt on my target hw. I successfully configured PORTE pin28 interrupt. However when I tried to do the same on PORTA same pin number. MCU is reseting. This specifically happens when I try to set a value in PORTA->DFER .
Any help is appreciated.
5 返答(返信)
3,209件の閲覧回数
adriancano
Can you please provide the information, which device is your target device?
Adrian
3,209件の閲覧回数
prakashpatel
I am using K10 series MCU.
Prakash
On Mon, May 26, 2014 at 3:28 PM, Adrian Sanchez Cano <
3,209件の閲覧回数
mjbcswitzerland
Specialist V
Do you power up PORTA (enable clocks to it) before writing to its registers?
Mark
3,209件の閲覧回数
prakashpatel
Thank you for your reply.
good question. I am enabling all clock. see following instruction.
SIM_SCGC5 |= 0x3E00UL
Prakash
On Mon, May 26, 2014 at 5:22 PM, Mark Butcher <[email protected]
3,209件の閲覧回数
prakashpatel
Kinetis K10 series
