FreeRTOS integration document
randyseedle
Is there a recent document that covers integration with NXP M4F microcontrollers(Kinetis 64) with FreeRTOS ? From looking at the FreeRTOS website, it appears that there examples do not cover the use of MCUXpresso compiler or most of your microcontrollers. All that I did see was the CORTEX_Kinetis_K60_Tower_IAR.
Celeste_Liu
Hello @randyseedle ,
Thanks  for your post.  You may refer to this: K64 FreeRTOS + USB CDC using MCUXpresso/SDK - NXP Community. No other recent documents.
Hope it helps.
Celeste
