First Time in-system Programming Procedure
RobMauro
What is the procedure for programming a "factory fresh" Kinetis device in-system?  Can a host processor program the part on initial start up?  Same question for reprogramming?
Tags (2)
LuisCasado
LuisCasado
You only have two options, JTAG/SWD or ezPort. Check AN4406
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4406.pdf?fsrch=1&sr=1
Luis
