FRDM-MKL82 porting guide MKL81Z128CBH7R
918件の閲覧回数
vitorciola
Hello!
Is there any porting guide to codes from FRDM-MKL82 to the MKL81Z128CBH7R ?
907件の閲覧回数
diego_charles
Thank you for reaching out.
We do not have a porting guide to move from MKL82 evaluation board (with a MKL82Z128VLK7 ) to a  MKL81Z128CBH7R custom design.
According to the Kinetis KL8x MCU Family  Factsheet  the KL81 adds only the tamper dedicated pins. So migrating your SW for the KL81 should be easy for you.
Please note that there is a dedicated SDK for the MKL81Z128xxx7 which is under controlled access, as you need an NDA for it.
I hope this helps,
Diego
