FRDM-KV11z PWM
FRDM-KV11z PWM
CMooN
I use MKV11Z128xxx7. I want to use FTM. How can I generate PWM output like a sinusoidal signal ?
Could you please help me ?
Thank you.
_Leo_
Thank you so much for your interest in our products and for using our community.
With the FTM it is not possible, a PWM is a square signal in principle. However, you could use the DAC to generate the sine signal you want.
Hope it helps you.
Have a nice day!
