FRDM-KL25Z miss U7 MMA8451Q
wangjianbing
The FRDM-KL25Z is missing the U7 MMA8451Q chip in the new version. This chip is an important component for this board, but I don't understand why it was removed.  Because of this, I can't use the board, yet the price has increased even though the chip has been removed. I need the old board. Please check, you removed the chip but didn't change the board model number, so when I ordered, I expected the old board, but I received the new one.
wangjianbing
Ok. i see. I have an issue please check it how to solution it. This version change is only removed U7? If i solder this U7 MMA8451Q in board. whether can use it like as older version? Now I need an solution to disposal it. Thanks!
bobpaddock
Senior Contributor IV
NXP sold all existing stock of most of their Accel/Gyros to Rochester Electronics several years ago. ST or Analog Devices is a better place to look for MEMs today.
If you are starting a new design the Kinetis line is not the line to do it in.
https://www.rocelec.com/global-search/MMA8451Q
Hello @wangjianbing
Thank you for contacting us. I’m sorry, we only have the new version (Rev.I) available, and the old version will no longer be produced. As noted on the FRDM-KL25Z homepage: “MMA8451Q accelerometer not soldered on Rev.I | MMA8451Q is no longer recommended for new designs.”
You may try contacting distributors or other third-party platforms to check if they still have stock of the previous version.
Thank you for your understanding.
Alice
