FRDM-K66/26 DWG/Gerber Files
1,737件の閲覧回数
whata
I've made a custom shield for both of my K66 and K26Z boards and now am in process of making a proper enclosure for both of these boards, however the mechanical documentation is practically non-existent which makes it pretty hard to make a proper enclosure. I believe that the same question has been asked several times, here, for instance. But no proper response was given because the files that were referred to are:
1. Missing the actual *.brd file for the PCB
2. Are in allegro format.  (Which can be viewed by a free viewer but cannot be exported)
Can someone from the kinetis team provide a proper neutral-format file for the K66 and K26 boards, something like a step or dwg file.
2 返答(返信)
1,582件の閲覧回数
fangli
We provide the Kinetis Symbols, Footprints and Models from here:
Kinetis Symbols, Footprints and Models|NXP
We do not provide the whole board gerber file as you asked for. Sorry.
1,582件の閲覧回数
whata
I'm not asking about the gerber sets since I'm not insterested in the layout of the pcb, just the outline of the board.
