FRDM-K64F PIT on different Rev boards
ソリューションへジャンプ
168件の閲覧回数
ve3id
I am experimenting with radio networking using six FRDM-K64F boards equipped with nrf23l01 transceivers.
I am splitting a second into ten time slots, the idea being that a transmission in slot 1 gets repeated in time slot 2, time slot 2 into time slot 3 etc for relaying.
So I am using PIT to generate interrupts at 100 ms periods, which I have checked on a scope.
On three boards, rev C,F, and F this is working fine and I am seeing the data on air being repeated.  However with the three rev F1 boards my transmit routine gets hung waiting for time slot 1 to come around. I am not getting the interrupt!
Does anybody know what changed between, say rev F and Rev F1 that would cause this behaviour?
Here is my init routine:
SIM->SCGC6 |= SIM_SCGC6_PIT_MASK; // Turn on clock to to the PIT PIT->MCR = 0x1; // Enable PIT timers
PIT->CHANNEL[0].LDVAL = 5999999; // Set reload value to 100mS
PIT->CHANNEL[0].TCTRL = 0x03; // Turn PIT timer 0 on, interrupts on
and in main:
NVIC_EnableIRQ(PIT0_IRQn); // Enable PI timer, ch 0 interrupt
and the ISR:
void PIT0_IRQHandler(void)
/* Clear interrupt flag */
PIT->CHANNEL[0].TFLG = PIT_TFLG_TIF_MASK;
NVIC_ClearPendingIRQ(PIT0_IRQn); // Clear pending PI timer, ch 0 interrupt
//scope_trigger();
time_slot +=1;
if (time_slot >10) time_slot=0;
__DSB(); // Add for ARM errata 838869, affects Cortex-M4
any help appreciated!
cheers
nigel
96件の閲覧回数
carlos_o
Hi @ve3id
The workaround mentioned with the errata is to put a read of the PIT_MCR register before writing it.
I use the PIT example of the SDK as base to test what you are doing in a FRDM board REV F1, I modified as following
It works without issues.
5 返答(返信)
131件の閲覧回数
ve3id
Aha! Thanks for that. Yes I have that mask on all three chips. I'm surprised that your AI engine that I have found very useful so far did not bring that up! Is there a suggested work-around? A delay or nops maybe? And yes, the PIT->MCR = 0x1; should be on a separate line, the <cr><lf>  must have have slipped out during cut and paste.
134件の閲覧回数
carlos_o
Hi @ve3id
Thank you for your post!
Please review if the errata e7914 applies for your MCU: Kinetis_K_1N83J.pdf
I've tested it in FRDM-K64F REV F1 and it works, I used SDK 2.11.0 and MCUXpresso IDE 25.06.
Also, I notice that in the code you share the "PIT->MCR = 0x1;" is included as a comment in the enablement of the SCGC6, I only want to confirm if that is a typo in the post
102件の閲覧回数
ve3id
I've changed my init code to this and still have the same problem:
delay(10);
volatile uint32_t PIT_MCR_read = PIT->MCR; // to overcome problem in 1N83J mask set errata 2026-09-22 NWJ
101件の閲覧回数
ve3id
I even changed the delay to 100 us and still no PIT action
97件の閲覧回数
carlos_o
Hi @ve3id
%3CLINGO-SUB%20id%3D%22lingo-sub-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-K64F%20PIT%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8BRev%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFNRF23L01%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F6%E6%9E%9A%E3%81%AEFRDM-K64F%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E7%84%A1%E7%B7%9A%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E5%AE%9F%E9%A8%93%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%E7%A7%92%E3%82%9210%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%E5%88%86%E5%89%B2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%82%B9%E3%83%AD%E3%83%83%E3%83%881%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%882%E3%81%A7%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%882%E3%81%AF%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%883%E3%81%AB%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%95%E3%82%8C%E3%82%8B%E3%80%81%E3%81%A8%E3%81%84%E3%81%86%E4%B8%AD%E7%B6%99%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPIT%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6100ms%E9%96%93%E9%9A%94%E3%81%A7%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3C%E3%80%81F%E3%80%81F%E3%81%AE3%E6%9E%9A%E3%81%AE%E5%9F%BA%E6%9D%BF%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E7%84%A1%E7%B7%9A%E3%81%A7%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%813%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3F1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E9%80%81%E4%BF%A1%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%83%AD%E3%83%83%E3%83%881%E3%81%8C%E5%9B%9E%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81Rev%20F%E3%81%A8Rev%20F1%E3%81%AE%E9%96%93%E3%81%A7%E4%BD%95%E3%81%8C%E5%A4%89%E3%82%8F%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%8C%99%E5%8B%95%E3%81%8C%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%AE%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESIM-%26gt%3BSCGC6%20%7C%3D%20SIM_SCGC6_PIT_MASK%3B%20%2F%2F%20PIT%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3CSPAN%3EPIT-%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMCR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x1%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20PIT%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EPIT%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%E3%80%82%3C%2FSPAN%3E%3CSPAN%3ELDVAL%3C%2FSPAN%3E%3CSPAN%3E%20%3D%205999999%3B%20%3C%2FSPAN%3E%3CSPAN%3E%20%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%89%E5%80%A4%E3%82%92100mS%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPIT%3C%2FSPAN%3E%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%3CSPAN%3ETCTRL%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200x03%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20Turn%20PIT%20timer%200%20on%2C%20interrupts%20on%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E4%B8%BB%E3%81%AA%E5%86%85%E5%AE%B9%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3ENVIC_EnableIRQ(PIT0_IRQn)%3B%20%2F%2F%20PI%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%80%81ch%200%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6ISR%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EPIT0_IRQHandler%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%94%E3%83%83%E3%83%88%E3%83%BB%26gt%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%E3%80%82%3C%2FSPAN%3E%3CSPAN%3ETFLG%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20PIT_TFLG_TIF_MASK%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENVIC_ClearPendingIRQ(%3C%2FSPAN%3E%20%3CSPAN%3EPIT0_IRQn%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AEPI%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3Ech%3C%2FSPAN%3E%20%3CSPAN%3E0%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%3C%2FSPAN%3E%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Fscope_trigger()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Etime_lot%20%2B%3D1%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eif%3C%2FSPAN%3E%20%3CSPAN%3E(time_slot%20%26gt%3B%2010)%20time_slot%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E__DSB()%3B%20%3C%2FSPAN%3E%3CSPAN%3E%20ARM%20%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AE%E8%A8%82%E6%AD%A3%3C%2FSPAN%3E%3CSPAN%3E%20838869%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81Cortex-M4%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%81%A9%E3%82%93%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B9%BE%E6%9D%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%8A%E3%82%A4%E3%82%B8%E3%82%A7%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKinetis%20K%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAMCU%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%82%EF%BC%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%AF3%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E4%BB%98%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%A8%E3%81%A6%E3%82%82%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A3%E3%81%9F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEAI%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E5%87%BA%E3%81%95%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E9%A9%9A%E3%81%8D%E3%81%A7%E3%81%99!%E4%BD%95%E3%81%8B%E4%BB%A3%E6%9B%BF%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E9%81%85%E5%BB%B6%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%A4%B1%E6%95%97%E3%81%8B%EF%BC%9F%E3%81%AF%E3%81%84%E3%80%81%20%3CSPAN%3EPIT-%26gt%3BMCR%20%3D%200x1%3B%20%E3%81%AF%E5%88%A5%E3%81%AE%E8%A1%8C%E3%81%AB%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%80%81%3CCR%3E%3CLF%3E%20%E3%81%AF%E5%88%87%E3%82%8A%E5%8F%96%E3%82%8A%E3%81%A8%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%AE%E9%9A%9B%E3%81%AB%E6%8A%9C%E3%81%91%E8%90%BD%E3%81%A1%E3%81%A6%E3%81%97%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FLF%3E%3C%2FCR%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3Ee7914%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEMCU%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Ferrata%2FKinetis_K_1N83J.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKinetis_K_1N83J.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFRDM-K64F%20REV%20F1%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SDK%202.11.0%E3%81%A8MCUXpresso%20IDE%2025.06%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%AD%E3%81%A7%E3%80%8CPIT-%26gt%3BMCR%20%3D%200x1%3B%E3%80%8D%E3%81%8CSCGC6%E3%81%AE%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%8A%95%E7%A8%BF%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%83%9F%E3%82%B9%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%81%85%E5%BB%B6%E6%99%82%E9%96%93%E3%82%92100%E7%A7%92%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81PIT%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%A4%E3%83%8B%E3%83%83%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%B6%9A%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%E9%81%85%E5%BB%B6(10)%3B%3CBR%20%2F%3E%E6%8F%AE%E7%99%BA%E6%80%A7uint32_t%20PIT_MCR_read%20%3D%20PIT-%26gt%3BMCR%3B1N83J%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%85%8B%E6%9C%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%202026-09-22%20NWJ%3CBR%20%2F%3EPIT-%26gt%3BMCR%20%3D%200x1%3BPIT%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%94%E3%83%83%E3%83%88%26gt%3B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%5B0%5D%E3%80%82LDVAL%20%3D%205999999%3B%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%89%E5%80%A4%E3%82%92100mS%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3EPIT-%26gt%3BCHANNEL%5B0%5D%E3%80%82TCTRL%20%3D%200x03%3BPIT%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC0%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A3%E8%AA%A4%E8%A1%A8%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AF%E3%80%81PIT_MCR%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%89%8D%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AFPIT%E3%81%AESDK%E4%BE%8B%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81FRDM%20REV%20F1%E3%81%A7%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396703i8AFE49F296FDC5BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carlos_o_0-1790096350978.png%22%20alt%3D%22carlos_o_0-1790096350978.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1790096350978.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
