FRDM-K64F PIT on different Rev boards
239 次查看
ve3id
I am experimenting with radio networking using six FRDM-K64F boards equipped with nrf23l01 transceivers.
I am splitting a second into ten time slots, the idea being that a transmission in slot 1 gets repeated in time slot 2, time slot 2 into time slot 3 etc for relaying.
So I am using PIT to generate interrupts at 100 ms periods, which I have checked on a scope.
On three boards, rev C,F, and F this is working fine and I am seeing the data on air being repeated.  However with the three rev F1 boards my transmit routine gets hung waiting for time slot 1 to come around. I am not getting the interrupt!
Does anybody know what changed between, say rev F and Rev F1 that would cause this behaviour?
Here is my init routine:
SIM->SCGC6 |= SIM_SCGC6_PIT_MASK; // Turn on clock to to the PIT PIT->MCR = 0x1; // Enable PIT timers
PIT->CHANNEL[0].LDVAL = 5999999; // Set reload value to 100mS
PIT->CHANNEL[0].TCTRL = 0x03; // Turn PIT timer 0 on, interrupts on
and in main:
NVIC_EnableIRQ(PIT0_IRQn); // Enable PI timer, ch 0 interrupt
and the ISR:
void PIT0_IRQHandler(void)
/* Clear interrupt flag */
PIT->CHANNEL[0].TFLG = PIT_TFLG_TIF_MASK;
NVIC_ClearPendingIRQ(PIT0_IRQn); // Clear pending PI timer, ch 0 interrupt
//scope_trigger();
time_slot +=1;
if (time_slot >10) time_slot=0;
__DSB(); // Add for ARM errata 838869, affects Cortex-M4
any help appreciated!
cheers
nigel
167 次查看
carlos_o
Hi @ve3id
The workaround mentioned with the errata is to put a read of the PIT_MCR register before writing it.
I use the PIT example of the SDK as base to test what you are doing in a FRDM board REV F1, I modified as following
It works without issues.
5 回复数
202 次查看
ve3id
Aha! Thanks for that. Yes I have that mask on all three chips. I'm surprised that your AI engine that I have found very useful so far did not bring that up! Is there a suggested work-around? A delay or nops maybe? And yes, the PIT->MCR = 0x1; should be on a separate line, the <cr><lf>  must have have slipped out during cut and paste.
205 次查看
carlos_o
Hi @ve3id
Thank you for your post!
Please review if the errata e7914 applies for your MCU: Kinetis_K_1N83J.pdf
I've tested it in FRDM-K64F REV F1 and it works, I used SDK 2.11.0 and MCUXpresso IDE 25.06.
Also, I notice that in the code you share the "PIT->MCR = 0x1;" is included as a comment in the enablement of the SCGC6, I only want to confirm if that is a typo in the post
173 次查看
ve3id
I've changed my init code to this and still have the same problem:
delay(10);
volatile uint32_t PIT_MCR_read = PIT->MCR; // to overcome problem in 1N83J mask set errata 2026-09-22 NWJ
172 次查看
ve3id
I even changed the delay to 100 us and still no PIT action
168 次查看
carlos_o
Hi @ve3id
%3CLINGO-SUB%20id%3D%22lingo-sub-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-K64F%20PIT%20%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%89%88%E6%9C%AC%E7%9A%84%E6%9D%BF%E4%B8%8A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%85%AD%E5%9D%97%E9%85%8D%E5%A4%87%20nrf23l01%20%E6%94%B6%E5%8F%91%E5%99%A8%E7%9A%84%20FRDM-K64F%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%97%A0%E7%BA%BF%E7%94%B5%E8%81%94%E7%BD%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E4%B8%80%E7%A7%92%E9%92%9F%E5%88%86%E6%88%90%E5%8D%81%E4%B8%AA%E6%97%B6%E9%9A%99%EF%BC%8C%E5%85%B6%E7%9B%AE%E7%9A%84%E6%98%AF%E8%AE%A9%E6%97%B6%E9%9A%99%201%20%E4%B8%AD%E7%9A%84%E4%BC%A0%E8%BE%93%E5%9C%A8%E6%97%B6%E9%9A%99%202%20%E4%B8%AD%E9%87%8D%E5%A4%8D%EF%BC%8C%E6%97%B6%E9%9A%99%202%20%E4%B8%AD%E7%9A%84%E4%BC%A0%E8%BE%93%E5%9C%A8%E6%97%B6%E9%9A%99%203%20%E4%B8%AD%E9%87%8D%E5%A4%8D%EF%BC%8C%E4%BE%9D%E6%AD%A4%E7%B1%BB%E6%8E%A8%E8%BF%9B%E8%A1%8C%E8%BD%AC%E5%8F%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%20PIT%20%E4%BB%A5%20100%20%E6%AF%AB%E7%A7%92%E7%9A%84%E5%91%A8%E6%9C%9F%E7%94%9F%E6%88%90%E4%B8%AD%E6%96%AD%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%A3%80%E6%9F%A5%E8%BF%87%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%89%E5%9D%97%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%88C%E3%80%81F%20%E5%92%8C%20F%20%E7%89%88%E6%9C%AC%EF%BC%89%E4%B8%8A%EF%BC%8C%E6%AD%A4%E5%8A%9F%E8%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E7%A9%BA%E4%B8%AD%E6%95%B0%E6%8D%AE%E9%87%8D%E5%A4%8D%E5%87%BA%E7%8E%B0%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%89%E5%9D%97%20rev%20F1%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E5%8F%91%E5%B0%84%E7%A8%8B%E5%BA%8F%E4%BC%9A%E5%8D%A1%E4%BD%8F%EF%BC%8C%E7%AD%89%E5%BE%85%E6%97%B6%E9%97%B4%E6%AE%B5%201%20%E5%88%B0%E6%9D%A5%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%B8%AD%E6%96%AD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E7%89%88%E6%9C%AC%20F%20%E5%92%8C%E7%89%88%E6%9C%AC%20F1%20%E4%B9%8B%E9%97%B4%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E5%8F%98%E5%8C%96%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%BF%99%E7%A7%8D%E7%8E%B0%E8%B1%A1%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESIM-%26gt%3BSCGC6%20%7C%3D%20SIM_SCGC6_PIT_MASK%3B%20%2F%2F%20%E5%BC%80%E5%90%AF%20PIT%20%E6%97%B6%E9%92%9F%20PIT%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMCR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x1%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%90%AF%E7%94%A8%20PIT%20%E5%AE%9A%E6%97%B6%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EPIT%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHANNEL%3C%2FSPAN%3E%20%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%20%3CSPAN%3ELDVAL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%205999999%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E8%AE%BE%E7%BD%AE%E9%87%8D%E8%BD%BD%E5%80%BC%E4%B8%BA%20100%20%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPIT%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHANNEL%3C%2FSPAN%3E%20%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%20%3CSPAN%3ETCTRL%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x03%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%BC%80%E5%90%AF%20PIT%20%E5%AE%9A%E6%97%B6%E5%99%A8%200%EF%BC%8C%E4%B8%AD%E6%96%AD%E5%BC%80%E5%90%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%BB%E8%A6%81%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3ENVIC_EnableIRQ(PIT0_IRQn)%3B%20%2F%2F%20%E5%90%AF%E7%94%A8%20PI%20%E5%AE%9A%E6%97%B6%E5%99%A8%EF%BC%8C%E9%80%9A%E9%81%93%200%20%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E5%8F%8A%20ISR%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EPIT0_IRQHandler%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPIT-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHANNEL%3C%2FSPAN%3E%20%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%20%3CSPAN%3ETFLG%3C%2FSPAN%3E%20%3CSPAN%3E%3D%20PIT_TFLG_TIF_MASK%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENVIC_ClearPendingIRQ(%3C%2FSPAN%3E%20%3CSPAN%3EPIT0_IRQn%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%B8%85%E9%99%A4%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%20PI%20%E5%AE%9A%E6%97%B6%E5%99%A8%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3E%E9%80%9A%E9%81%93%3C%2FSPAN%3E%3CSPAN%3E0%20%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2Fscope_trigger()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Etime_slot%20%2B%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%E6%97%B6%E9%97%B4%E6%AE%B5%20%26gt%3B%2010%EF%BC%89%E6%97%B6%E9%97%B4%E6%AE%B5%20%3D%200%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E__DSB()%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%B7%BB%E5%8A%A0%E4%BB%A5%E5%BA%94%E5%AF%B9%20ARM%3C%2FSPAN%3E%3CSPAN%3E%E5%8B%98%E8%AF%AF%E8%A1%A8%3C%2FSPAN%3E%3CSPAN%3E838869%EF%BC%8C%E5%BD%B1%E5%93%8D%20Cortex-M4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%B9%B2%E6%9D%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A5%88%E6%9D%B0%E5%B0%94%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2415032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKinetis%20K%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8A%E5%93%88%EF%BC%81%E8%B0%A2%E8%B0%A2%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%9A%84%E4%B8%89%E4%B8%AA%E8%8A%AF%E7%89%87%E4%B8%8A%E9%83%BD%E8%A3%85%E4%BA%86%E9%82%A3%E4%B8%AA%E9%9D%A2%E7%BD%A9%E3%80%82%E6%88%91%E5%BE%88%E6%83%8A%E8%AE%B6%EF%BC%8C%E4%BD%A0%E4%BB%AC%E7%9A%84AI%E5%BC%95%E6%93%8E%EF%BC%88%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E6%88%91%E8%A7%89%E5%BE%97%E5%AE%83%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%89%E7%AB%9F%E7%84%B6%E6%B2%A1%E6%9C%89%E6%8F%90%E5%87%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%81%E6%98%AF%E5%90%A6%E6%9C%89%E5%BB%BA%E8%AE%AE%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9F%E5%BB%B6%E8%BF%9F%E6%88%96%E5%A4%B1%E8%B4%A5%EF%BC%9F%E6%98%AF%E7%9A%84%EF%BC%8C%20%3CSPAN%3EPIT-%26gt%3BMCR%20%3D%200x1%3B%20%E5%BA%94%E8%AF%A5%E5%8D%95%E7%8B%AC%E4%B8%80%E8%A1%8C%EF%BC%8C%3CCR%3E%3CLF%3E%20%E8%82%AF%E5%AE%9A%E6%98%AF%E5%9C%A8%E5%89%AA%E5%88%87%E7%B2%98%E8%B4%B4%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%B8%A2%E5%A4%B1%E4%BA%86%E3%80%82%3C%2FLF%3E%3C%2FCR%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E5%8B%98%E8%AF%AF%E8%A1%A8%20e7914%20%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%E6%82%A8%E7%9A%84%20MCU%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Ferrata%2FKinetis_K_1N83J.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKinetis_K_1N83J.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%20FRDM-K64F%20REV%20F1%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E8%BF%87%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20SDK%202.11.0%20%E5%92%8C%20MCUXpresso%20IDE%2025.06%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E5%9C%A8%E5%90%AF%E7%94%A8%20SCGC6%20%E7%9A%84%E4%BB%A3%E7%A0%81%E9%87%8C%EF%BC%8C%E6%9C%89%E4%B8%80%E8%A1%8C%E2%80%9CPIT-%26gt%3BMCR%20%3D%200x1%E2%80%9D%E4%BD%9C%E4%B8%BA%E6%B3%A8%E9%87%8A%EF%BC%8C%E6%88%91%E6%83%B3%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E5%B8%96%E5%AD%90%E4%B8%AD%E7%9A%84%E7%AC%94%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%8B%98%E8%AF%AF%E8%A1%A8%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%E5%9C%A8%E5%86%99%E5%85%A5%20PIT_MCR%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B9%8B%E5%89%8D%E5%85%88%E8%AF%BB%E5%8F%96%E8%AF%A5%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%A5SDK%E4%B8%AD%E7%9A%84PIT%E7%A4%BA%E4%BE%8B%E4%B8%BA%E5%9F%BA%E7%A1%80%EF%BC%8C%E5%9C%A8FRDM%E6%9D%BFREV%20F1%E4%B8%8A%E6%B5%8B%E8%AF%95%E6%82%A8%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%A6%82%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1790096350978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396703i8AFE49F296FDC5BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carlos_o_0-1790096350978.png%22%20alt%3D%22carlos_o_0-1790096350978.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1790096350978.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1790096350978.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1790096350978.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E5%B7%B2%E5%B0%86%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%E6%9B%B4%E6%94%B9%E4%B8%BA%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%9A%3CBR%20%2F%3E%E5%BB%B6%E8%BF%9F(10)%EF%BC%9B%3CBR%20%2F%3E%20volatile%20uint32_t%20PIT_MCR_read%20%3D%20PIT-%26gt%3BMCR%3B%20%2F%2F%20%E4%B8%BA%E4%BA%86%E8%A7%A3%E5%86%B3%201N83J%20%E6%8E%A9%E7%A0%81%E9%9B%86%E5%8B%98%E8%AF%AF%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%882026-09-22%20NWJ%EF%BC%89%3CBR%20%2F%3E%20PIT-%26gt%3BMCR%20%3D%200x1%3B%20%2F%2F%20%E5%90%AF%E7%94%A8%20PIT%20%E5%AE%9A%E6%97%B6%E5%99%A8%3CBR%20%2F%3EPIT-%26gt%3BCHANNEL%5B0%5D.LDVAL%20%3D%205999999%3B%20%2F%2F%20%E8%AE%BE%E7%BD%AE%E9%87%8D%E8%BD%BD%E5%80%BC%E4%B8%BA%20100%20%E6%AF%AB%E7%A7%92%3CBR%20%2F%3EPIT-%26gt%3BCHANNEL%5B0%5D.TCTRL%20%3D%200x03%3B%20%2F%2F%20%E5%BC%80%E5%90%AF%20PIT%20%E5%AE%9A%E6%97%B6%E5%99%A8%200%EF%BC%8C%E4%B8%AD%E6%96%AD%E5%BC%80%E5%90%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-K64F%20PIT%20on%20different%20Rev%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E7%94%9A%E8%87%B3%E6%8A%8A%E5%BB%B6%E8%BF%9F%E6%97%B6%E9%97%B4%E6%94%B9%E6%88%90%E4%BA%86%20100%20%E5%BE%AE%E7%A7%92%EF%BC%8C%E4%BD%86%20PIT%20%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E5%8F%8D%E5%BA%94%E3%80%82%3C%2FLINGO-BODY%3E
