FNET and FatFS
FNET and FatFS
weblar
Contributor V
I have an application which uses the FatFS file system, to which I'm wanting to add the FNET ethernet stack and services.
As FNET already has a file system implementation, is there a simple way of pointing the fs functions from FNET to the FatFS api?
Kev
Tags (3)
alejandrolozan1
HI Kev,
Sorry for the delay. I have contacted the author of FNET to confirm.
You can implement a driver for your own FS and plug it into FNET, via fnet_fs_register().
I hope this helps,
Alejandro
alejandrolozan1
HI Kev,
I hope this helps,
Alejandro
weblar
Contributor V
Hi Alejandro,
Thanks for your feedback. I shall look into the fnet_fs_register() function.
Kev
alejandrolozan1
Hi Kev,
I will delve into this. I will get back to you as soon as I have something helpful.
Alejandro
