Dear Ludek,
I´m working with the TWR-KM34Z50.
Do you know if it´s possible to work with the SD-ADC in Continous Convertion Mode triggered by hardware?
Would you mind sharing the whole source code with the configutation of the AFE that you have in the example code?
Thanks.
Omar
SD-ADC works in continuous conversion mode too. For the application source code see DRM163 (1-ph meter) or DRM149 (2-ph meter).
