Error in final launch sequence
9,658件の閲覧回数
liuzhonghuiliu
Error in final launch sequence Failed to execute MI command: -target-select remote localhost:3333 Error message from debugger back end: localhost:3333: ϵͳÊÔͼ½«Çý¶¯Æ÷ºÏ²¢µ½ºÏ²¢Çý¶¯Æ÷ÉϵÄĿ¼¡£\r\n. Failed to execute MI command: -target-select remote localhost:3333 Error message from debugger back end: localhost:3333: ϵͳÊÔͼ½«Çý¶¯Æ÷ºÏ²¢µ½ºÏ²¢Çý¶¯Æ÷ÉϵÄĿ¼¡£\r\n. localhost:3333: ϵͳÊÔͼ½«Çý¶¯Æ÷ºÏ²¢µ½ºÏ²¢Çý¶¯Æ÷ÉϵÄĿ¼¡£\r\n.
12 返答(返信)
9,107件の閲覧回数
Robin_Shen
Hi liuzhonghui,
Would you please show me below information:
what IDS
the version of IDE
what debugger
how did you connect the debug interface
Robin
9,107件の閲覧回数
liuzhonghuiliu
KDS3.0
Open OCD
OpenOCD - On-board OpenSDA debug interface
running the ARM® mbed™ project CMSIS-DAP
firmware
9,107件の閲覧回数
Robin_Shen
Please try to use the latest KDS3.2 IDE and latest firmware application.
If you just started this project, see also: MCUXpresso Software and Tools for Arm Cortex-M cores.
The MCUXpresso SDK, IDE and configuration tools speed development time with highest quality software and tools for Kinetis and LPC microcontrollers.
Robin
9,107件の閲覧回数
josephg
Robin,
Thank you very much.  I have been working on an error in final launch sequence problem for ten days now.  I reloaded the latest firmware application and BINGO!!!!  My problem was fixed.  Again thank you so much!
9,107件の閲覧回数
liuzhonghuiliu
Hi Robin_Shen
我的操作系统是win7 home,IDE是KDS3.2,开发板是TWR-KV58F220M Tower Module,debug时出现
'Lauching hello_world_twrkv58f220m debug' has encountered a problem.
文件发送到上,也会发生此类错误,故出现
这个问题如何解决?
9,107件の閲覧回数
Robin_Shen
请检查TWR-KV58F220M的RESET_B电压是否为稳定的3.3V
另外KDS是否尝试过切换新的workspace?
9,107件の閲覧回数
liuzhonghuiliu
Hi Robin_Shen
    监测 TWR-KV58F220M的RESET_B电压一直稳定在3.27V。另外KDS也没有尝试切换到新的workspace。
9,107件の閲覧回数
Robin_Shen
尝试将默认板载的OpenOCD切换成PE Micro或者Segger OpenSDA吧。(请从附件下载这些文件)
Robin
9,107件の閲覧回数
liuzhonghuiliu
好吧!我试试。谢谢!
9,107件の閲覧回数
liuzhonghuiliu
Hi Robin_Shen
使用PE Micro,可以debug了!
多谢!
Best Regards!
9,107件の閲覧回数
liuzhonghuiliu
谢谢!我试试。
9,107件の閲覧回数
liuzhonghuiliu
还是不行!我现在的软件都是最新版本的!
操作系统是win7。IDE是KDS3.2。问题没解决。
