Error : Download size limit has been exceeded. Please check your license
4,083 次查看
kbhat
I've been using MK10FX512VLQ12 controller for development and came across an error stating :
"Failed to resume target process. Download size limit has been exceeded. Please check your license"  while I try to download the code.
I'm using Code Warrior 10.7 IDE. I tried re-installing the IDE, still it didn't work.
Memory size is as below:
text          data         bss        dec         hex
137232    92       11748     149072     24650
Please help. Awaiting responses.
Thanks.
标签 (1)
3 回复数
4,052 次查看
mjbcswitzerland
Specialist V
Have you enabled full optimisation to possibly reduce the code size?
Regrds
Mark
4,016 次查看
kbhat
Hi Mark,
Yes I have tried enabling full optimisation and it does reduce the code size. But the FW malfunctions probably due to some timing issues, because of code optimization.
4,059 次查看
Alexis_A
Hello @kbhat,
Unfortunately, the evaluation license for CodeWarrior only supports up to Kinetis K 128 KB. Please check here features for each CodeWarrior License (link).
Alexis Andalon
