ESD kinetis k64-82
ESD kinetis k64-82
1,667 次查看
flauberttagu
I want to know what is the maximum electric charge k64 and k82 microcontroller can support.
To be more specific, what is the ESD limit on this microcontrollers?
Thank you for your help.
Sincerly.
1 回复
1,566 次查看
adriancano
You can see data on the specific device data sheet in section ESD handling ratings. In example, for K64 https://www.nxp.com/docs/en/data-sheet/K64P142M120SF5.pdf
Hope the information helps.
Adrian
